Old 04-04-2018   #1
Diwiak has donated!
Slovakia
2001'Sei 1108 MPi Water pump?
Iam ordering parts for next service, and for a water pump EPER and online catalogue is showing more options - biggest difference is in teeth number - 20 vs 24.
Anyone knows which will fit??
2001'Sei Brush 1108 MPi 187AXC1A, eng. number 0848146, timing belt is 15mm wide with 125 teeth.
Thanks!!
https://www.autodielyonline24.sk/zna...adlo.html?pg=2
Brand new Panda Plus(319) arrives with 1.2 69k EURO6 S&S in Sicilia Orange
Diwiak is offline Reply With Quote Quote
Old 04-04-2018   #2
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: 2001'Sei 1108 MPi Water pump?
Based on that and your engine number I'd say you want the 20 tooth version.
Thanks htchd7 thanked for this post
Eklipze3k is offline Reply With Quote Quote
Old 05-04-2018   #3
Trader Rating: 1
cc1 has donated!
24 teeth on all MPI versions. You can fit a Grande Punto 1.2 8v pump that has a larger impeller. Increases flow rate.
Likes htchd7, Fiatfan13 liked this post
cc1 is offline Reply With Quote Quote
Old 06-04-2018   #4
Diwiak has donated!
Slovakia
I ordered both of them(local warehouse-free returns), will replace it tommorow in case of good weather :-) and let you know. Thanks.
What do you think of MEYLE, HEPU brands?
Old 27-04-2018   #5
Diwiak has donated!
Slovakia
Thanks, youre right, its a 24teeth.
Likes Jamieboy liked this post
Old 02-05-2018   #6
Thanks for the information. I will soon change mine and you have saved me time trying to identify the correct item.
Jamieboy is offline Reply With Quote Quote
Old 10-09-2018   #7
Ireland
Hi I know this post is old and Iím new and probably should post this elsewhere but I may start on my list of problems , my engine fan only works when I disconnect the temp sensor , but also as I bled the coolent I found the coolent pours from the little hoses I was expecting more pressure ,I also notice the coolent is red ?should it be blue ?Iím going to change the timing kit I and seem to have an mpi (2003) so a 125 tooth belt then?and can I use a better punto pump as someone mentioned a Grande Punto 8v ? What pumps are suitable ?very Grateful for Any advice .
Fiatfan13 is offline Reply With Quote Quote
Old 10-09-2018   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Is yours an MPi?
D
Old 10-09-2018   #9
Ireland
Hi I think it is itís an 03
Old 16-09-2018   #10
Serbia
Quote Originally Posted by cc1 View Post
That is awsome thing to know. Thanks
@ Fiatfan13, I also have 2003 Sei Abarth MPI. I will change by belt and pump in February or March.
It is the same 125 tooth belt and I will try to use Grande Punto pump.
Now I have problem with fog lights that I need to sort out.
Do you have Sei manuals downloaded?
htchd7 is offline Reply With Quote Quote
Old 16-09-2018   #11
Ireland
Hi htchd , il follow your belt change and pump and if that pump works out for you il be doing the same if I do mine first il let you know ,really struggling with the fan on mine did a flush and fresh coolent today , every little helps I suppose
Likes htchd7 liked this post
(T) Water Pump and Manual for 2001 Seicento CasLad Cinquecento / Seicento 11 10-02-2014 14:22
(T) 2001 Sei Mpi flatspot 3.5k??? ronnieronson Cinquecento / Seicento 7 07-01-2008 12:12
Supersprint Exhaust Manifold Cinq/Sei 1108 MPI/SPI Poss 1242 J.R Racing Auction Watch 5 08-03-2007 11:06
(T) Sportex Manifold on a Sei Sporting MPi 2001? rich_lufc Cinquecento / Seicento 10 06-04-2006 08:56
