Technical Creaking/clicking while driving from front right
So I went for a drive today and after a little while I started hearing a clicking noise as I was going along so I stopped to have an investigate and found that at low speeds it was more of a creak when the wheel gets to a certain point in it's rotation. I drove forwards and backwards a few times with my head out the window to confirm it was definitely the front right wheel and to try to work out what it could be. It tracks straight, no vibration on or off brakes or funny feeling when cornering, no play in the wheel bearing, sometimes steering made it quiter, sometimes not. It was fine before yesterday when I had that wheel off to reinflate the tyre my mate let down (something about hitting him in the balls annoyed him for some reason) and this was the first time I'd driven it since then. The clicking is loudest around 20-25mph and then gets a little quiter and is definitely wheel speed dependant. I call it clicking but it's more the creak that I hear at very low speeds sped up so it sounds closer to a click. I'll have a proper look at it at the weekend but just wanted to know if anyone's had that problem before and might be able to point me in the right direction.
Yep just checked it before I saw your comment and for whatever reason, 2 of them were just finger tight and one took minimal effort from a wrench to break loose. I tightened them up and voila no more creaking. I had put them on with an impact gun while the wheel was in the air so I'm guessing it didn't tighten properly and then rattled loose. My wheel didn't fall off so I guess I only need 1 bolt :p. I'll actually torque them properly this time and I'll go round and check the others as well although I did actually torque them last time they went on.
Just went round and all of them had come loose slightly, but all by roughly the same amount and not catastrophically so. I assume they've just come loose over time but I'll have to properly keep an eye on it.
