My trusty everyday driver 1108cc Seicento has been suffering from a mysterious and occasional slight coolant loss in recent months. Additionally the heater has been poor, offering only luke-warm air after a long run. I checked the two bleed valves under the bonnet and they both dribble water when opened. Often immediately after switching the engine off after a run, various odd glugs and bubblings can be heard from the engine compartment.
This morning (which was very cold!) I noticed there was no heat at all coming out of the vents, so had a chilly 30 mile commute to work. Just as I arrived at work the temperature warning light came on. Opening the bonnet revealed steam and after leaving it for ten minutes to cool slightly, careful loosening of the header tank cap caused the coolant to start to spray out enthusiastically. Obviously my first thought was 'head gasket!' yet there was no mayonnaise in the oiler filler cap, the engine idled as smoothly as usual and no white smoke was to be seen from the exhaust.
I managed to get home with the water topped up and the header tank cap just on a couple of loose turns so the system didn't pressurize. Apart from frequent stops to check the coolant level (which initially increased, before starting to go down) the car drove as well as ever. I did notice though that that the left side of the engine (i.e. drive belt end) was fairly thoroughly wet below under the header tank, as though water had been spraying around, although the tank itself hadn't been overflowing and watching the engine at idle didn't highlight any obvious source of the water.
From the above does it seem likely that the problem is with the head gasket or elsewhere? I'm wondering why the heater went stone cold and the coolant boiled. It does sound like a major air lock of some kind. I probably won't be able to check the car in daylight until the weekend, but thought I'd collect a few opinions from fellow Cento owners in the meantime...
Sorry for the long post!
Steve
Steve
