SeiSporting11
- Jul 14, 2017
- 14
- 3
Guys and Girls! Being an employee within a mechanical garage, I know my way around MoSt problems when it comes to cars! BUT, my wifes car is doing me in! I wonder if one of you kind Fiat owners could help? The Car....Fiat Seicento (187) 2002 1.1 Sporting MPI. Problem: (especially when warm) starts to kangeroo, and reek of fuel, not revving above 2k rpm, and does no more than 30mph until stalling! Starts straight up and drives for 1 min - 10 minutes before dying again! ONLY code and ONLY once was fuel trim bank 1! So I have replaced...upstream lambda sensor, throttle position sensor, MAP sensor, coolant temp sensor, crank sensor, cam sensor, coil packs, HT leads, plugs, cambelt w/pump (13/7/17) but STILL dhe spits and coughs! generally worse when warmer weather and engine temp! I can not find the fuel filter for love nor money (have found charcoal canister behind passenger arch) so is the fuel filter part of the fuel pump? or is it seperate but in with the pump? There is NO fuel filter under neath the car either! But have currently spent out over £400 on sensors and such like and am fast running out of patience and money! TIA and sorry for the essay, but all information is above
