Old 10-07-2017   #1
Lover of Mischief
DRSIK's Avatar
DRSIK has donated!
Stuttering loss of power on acceleration
Hi Folks
Having a bit of fun with the mischief machine.
It has started to "bog down" when I try to accelerate. (loss of power - that sort of returns when the foot is off the accelerator....also tick over is lovely and smooth)
I have already replaced the crank sensor recently and also no "injector light" is coming on.
THis meant I suspected the MAP sensor so I got one from fleabay and now the problem is even worse !!!
I will check over the next couple of days if my fitting skills have deserted me but in the meantime does anyone have any ideas ?
DRSIK is offline Reply With Quote Quote
Old 10-07-2017   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Stuttering loss of power on acceleration
vacuum leak
D
Old 11-07-2017   #3
Lover of Mischief
DRSIK's Avatar
DRSIK has donated!
Hi Mate - where shall I look for that ?
Old 17-07-2017   #4
Lover of Mischief
DRSIK's Avatar
DRSIK has donated!
Fitted new Map sensor and pipe to throttle body.
Checked Vacuum take of to brakes
No change still behaves like it has a choke (nice tickover - "bogs down" when throttle is pressed quickly)
Unplugged MAP sensor same symptoms - only difference is the engine (injector light) comes on.
Any ideas ?
Old 24-07-2017   #5
Lover of Mischief
DRSIK's Avatar
DRSIK has donated!
Put back on the old sensor - a bit better than the new one!!!!
Also replaced all tubing from carb to MAP with OEM parts.
Still not great - any more thoughts.
Old 24-07-2017   #6
Clean the stepper motor - the air idle valve?
glenn2602 is offline Reply With Quote Quote
Old 24-07-2017   #7
Lightbulb Re: Stuttering loss of power on acceleration
MAY or MAY NOT be related, but sounds similar as to how my wifes started, now, hopefully solved!! We had a build up of crap in the bottom half of the fuel filter, having replaced this seems to have solved our issue touch wood and fingers corssed etc! may be worth even having a look?
cheers
Tom
Thanks Moimo thanked for this post
SeiSporting11 is offline Reply With Quote Quote
Old 25-07-2017   #8
Lover of Mischief
DRSIK's Avatar
DRSIK has donated!
I have a new Fuel filter - fitting tonight
Stepper motor is new - only used decent fuel so hopefully OK
Old 25-07-2017   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Has it got the standard air filter on it?
D
Old 26-07-2017   #10
hmmmm hopefully you will get to the bottom of it!! I have soent nesr on 500 on sensors and what not until the last thibg (fuel filter) lol
Old 27-07-2017   #11
Mine did this i changed lamba sensor sorted mine id done the same map sensor coils leads plugs fuel filter
peter33 is offline Reply With Quote Quote
Old 15-08-2017   #12
Lover of Mischief
DRSIK's Avatar
DRSIK has donated!
I have done the MAp sensor and Fuel filter.
Still has lovely tick over and drives well until hot.
Then I still get some "flatspots" and lag that I did not get before.
There maybe a slight blow at the exhaust manifold - could this or LAMDA be the problem
Old 16-08-2017   #13
Quote Originally Posted by DRSIK View Post
I did the same new lamba and its sorted mine out
Likes DRSIK liked this post
Old 16-08-2017   #14
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
its plausible... the lambda isn't used until car warms up a bit.
Likes DRSIK, peter33 liked this post
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 16-08-2017   #15
Quote Originally Posted by blu73 View Post
Alright blu u got a cinq again mate
(T) Loss of power under acceleration... Smokey22 Cinquecento / Seicento 6 11-11-2013 05:51
(G) Power loss on acceleration?... D8DEL Panda 3 23-07-2011 20:09
(T) Punto Stuttering \ Juddering \ Loss of Power Car nut Punto (Mk2/2b) 2 19-04-2009 12:22
(T) Loss of power during acceleration piggylou Punto (Mk2/2b) 19 17-09-2008 22:07
(T) stuttering and power loss Jayjj Bravo / Brava 7 02-10-2007 19:48
