I found an 866 in a scrap punto 60. The problem is when I cleaned it up one of the lobes looked a bit worn. I have measured its height and it is indeed a couple of mm smaller than it should be.
The worn lobe is still taller than the 4x4 cam but lower than the Cinq cam.
I wonder if I fit the worn camshaft will it cause problems or cause a noticeable difference?? Basically is it worth installing it... i wad planning to use it in an mpi sei
