mar cu para
- Oct 19, 2016
- 5
- 1
Hi all,
I have a Seicento made in 2001 and i have a disturbing problem.
Whiale the engine is running on idle, the light for system overheating is turning on.
If i am moving i don t have this problem.
I checked the fan and it is working properly.
First i changed the thermocouple, because i thought that it is the reason for the fan is not running. After this i still have the problem
Second i changed the thermosensor from the themostat. i thought that is too old and it s not functioning at the parameters, transmiting wrong measurements. Still have the problem.
Third i changed the thermostat. Still have the problem.
Any ideeas where is the problem and how to solve it
P.S. i don t have oil in the cooling liquid.
The fan is not starting on idle.
Thank you for your time and i hope that i will find an answer to my problem.
