Thread Tools
Old 01-11-2005   #1
Coolant temperature problem?
My Cinq sporting is only running at 70 degrees- Is this normal? Takes a long,long time to get to this temperature too. (about 5 miles)
Ive already had another head (done by a garage) that was from a punto (same engine apparently?) with the nessesary bolts and gasket.
Coolant has been replaced when they did the head,theyve replaced all the core plugs (6 I think) and the rad has had some stop leak in it (or equivelent) even though it wasnt leaking.
Doesnt use coolant (on max) and the fan cuts in at 90 when in traffic. Cant see any leaks either.
What the hecks going on? Im well confused
Sonic2 is offline Reply With Quote Quote
Old 01-11-2005   #2
Re: Coolant temperature problem?
I will add to say it doesnt stay at one temperature either (when driving along)-It can fluctuate between 60?! and 90 when in traffic,but wont ever go over 90.
I think the temperature drops right down when it goes up or downhill,if thats any help.
Waterpump has also been replaced.
Old 01-11-2005   #3
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
thermostat could be jammed open or even removed
Old 01-11-2005   #4
I guess it could be jammed open... sometimes ,but I cant see how that would explain how it would be missing if the fan cuts in!
Old 01-11-2005   #5
1. Thermostat missing or jammed open.
2. Temp sender ******ed.
3. Temp guage ******ed.
4. Air trapped in head. try opening the bleed screws see if you can get any water out
primeruss is offline Reply With Quote Quote
Old 01-11-2005   #6
custard's Avatar
Trader Rating: 1
Quote Originally Posted by Sonic2
because when the engine is at full temp the thermostat would be fully open anyway
Old 01-11-2005   #7
Ah,i see.
Fully open-Possability.
Missing- Cant see how
I'll see if I can source a 'stat,Cheers
Old 01-11-2005   #8
Ah,i see.
What happens is this.............
It is a hot day in may and your thermostat decides to pack up. Instead of spending 20 on a new one you simply take the housing off the end of the block and break the waxstat part inside ( hammer is useful for this) You then put it back together without the internal parts, smug in the knowledge that your car won't overheat no matter how hot the summer is, unfortunately the summer endes around October and you then need to put a new thermo in otherwise the heater won't work, the car runs rough for about 20mins after start up, temp never gets above 70, fuel consumption drops off the scale.
Old 01-11-2005   #9
Thing is,ive owned the car for years. So if the garage have done it they'll be having a few questions put their way...
Eg do they have a good solicitors
Old 01-11-2005   #10
take it off and have a look. It may be stuck open but to run as cold as you suggest it sound like there is nothing in it or the problem lies elsewhere
Old 01-11-2005   #11
Thing is,fuel consumption is good.... I think- 350 miles to a tank (30) with moderate driving.
Heater takes a while to get warm,but at 70 deg. it clears ok-How do I check to see if the stat's still there/looks ok?
o,hang on,ive got a haynes manual at home,I'll look at that at the weekend
Old 01-11-2005   #12
J333EVO has donated!
I would say if it runs about 70'c its doing what its meant to. I tried my car with no thermo to test how good the rest of the system is at cooling, and it didn't even move onto the scale, sat right on the bottom which is what 50'c, and this was with a turbo in summer, no heaters at all, just warm at best. 90'c in traffic is normal as the fan is set to come on at 92'c off at 87'c which would look about 90'c on the gauge, therefore again as it should be.
THe other thing is at this time of year and with the changeable weather we have had people tend to jump into the car and stick the heaters on which in turn means the engine takes longer to heat up, 5 miles of driving is hardly a long time, how ling does that take you 10mins as best, thats the way it should be, your car is running fine so stop worrying.
Aaron.
Cinquecento Abarth 1.4 16V 6speed track toy
Lancia integrale EVO1 Homologation model
MINI Clubman Hampton Edition Cooper SD
VW MK5 Golf R32
J333EVO is offline Reply With Quote Quote
Old 01-11-2005   #13
Cocoon Island Champion, Cupids Crush Champion, Crazy Pinball Champion, Pinball 7UP Champion, Rotamania Champion, Starsky n Hutch PinBall Champion
easiest way to check for airlocks is to wait until the fan cuts in,then feel how hot the bottom pipe is.if its tepid along one end,you have an airlock.i would say its ok as it is.when hot,is the heater hot also?
sumplug is offline Reply With Quote Quote
Old 01-11-2005   #14
hi friends :waves:
Liam's Avatar
Liam has donated!
I agree with Aaron (J333 EVO), sounds perfect to me.
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 02-11-2005   #15
Ok,I see your point,but if I dont use the heater then the guage has been going down as low as 55 degrees and the car is getting really sluggish then,it just doesnt seem right.
When its hot,yes the heater works well,just that a lot of the time I get condensation in the windows as the car isnt getting up to a reasonable temp.
Ive got a feeling it might use a little bit of coolant if it was stuck in traffic for ages but its a 10 year old car,so its bound too. But when in traffic and at 90 deg for example you'll see mist coming out the vents where the heater matrix is,Is that normal?
I just get the impression 55 degrees is way too cool for an engine to be running at,and the lack of power makes it feel like its not right too
Is it possible for an engine to run so cool and it wont cause any damage?
Thread Tools
(T) Solution to Punto 75 mk1 Engine Problem Tziallas Punto (Mk1) 8 10-09-2010 08:17
(T) Crazy temperature gugue coedkernew Punto (Mk2/2b) 4 30-08-2005 16:10
(T) coolant temperature Drinu Uno 18 22-04-2005 18:05
(T) Major Problem With Engine Overheating JTD Maxman Stilo 2 13-01-2005 10:02
(T) Temperature Guage problem barachello2000 Bravo / Brava 5 22-04-2004 15:49
