My Cinq sporting is only running at 70 degrees- Is this normal? Takes a long,long time to get to this temperature too. (about 5 miles)
Ive already had another head (done by a garage) that was from a punto (same engine apparently?) with the nessesary bolts and gasket.
Coolant has been replaced when they did the head,theyve replaced all the core plugs (6 I think) and the rad has had some stop leak in it (or equivelent) even though it wasnt leaking.
Doesnt use coolant (on max) and the fan cuts in at 90 when in traffic. Cant see any leaks either.
What the hecks going on? Im well confused :bang:
