Sporty_5_Seicento
Member
My son has jsut bought a Seicento 2000 sporting.
The gearbox crunches as you change from 1st gear to 2nd or from 3rd gear to 2nd. However it only happens after a peroid of time when the gearbox has warmed up.
The previous gearbox in the cinquecento had ep80 oil the Seicento 2000 gearbox has been changed to a synthetic oil. Would putting ep80 back into the Seicento gearbox help the problem?
Could it be the Second Gear syncro in the Seicento gearbox thats worn preventing it from selecting second? If so why doesn't it crunch between the gears when te gearbox is cold?
Has anyone got a gearbox manual for the 2000 Seicento sporting model could you please email me at [email protected].
Does anyone who which gearboxes will fit the 2000 Seicento Sporting range. On the Seicento the gearbox mounting is on the top of the gearbox whereas previous models are at the front of the gearbox such as the cinquecento.
All guidence is much apreciated
Many Thanks
Brian Cornwell
Many Thanks
Brian Cornwell
