Like i said, they are a bit finecky and the brackets need to be spaced perfectly, aligned the right way etc, they do sometimes take a little adjustment to sort.
My guess, if the car belonged to an older couple, was the clutch has been changed (probably because the thrust bearing wore through the fingers through riding the clutch, rather than pressure plate wear) and the repairer just forgot how they went together.
