DocHoliday
- May 16, 2016
- 3
- 1
Can anyone help please?
I've got a 2000 Seicento 1.1 and it's overheating. I checked the fan and it was sticking, so I had it off the car and found the motor was totally rusted. Straight in the bin and new one fitted. Thought that would be the end of the drama.
But no, came to use the car about three hours later and the battery is absolutely dead. Seeing as there's only one connector to the fan (with two pins of course) I couldn't fathom how I could have indices an earth leakage. Decided to back out of the situation by disconnecting the fan electrically (but leaving in place) and everything is back to as it was i.e. no fan assisted cooling and overheating.
Any ideas?
Have bought a replacement coolant switch but a quick look at the installed electrical properties and there appears to be nothing wrong with the current one. So started focusing on the 'coolant temperature sender' - at least that's what I think it's called as I have no manual or electrical circuit to go on. Turns out these are about £88 from a Fiat dealer which I regards as a bit steep. The only problem is, the diagram they have sent me indicates a unit with two terminals. Mine only has one electrical connection (and a screwed fitting of course). Going back to on elf my problems I can't get a Haynes manual for anything other than a Cinqcento and the electrics seems different on this car, as it's got a temperature indicator on the dash (mind doesn't).
Any pointers anyone?
Any ideas?
