Rob_Randomcruisers.co.uk Established member Joined Jan 10, 2005 Messages 400 Points 163 Location Swindon, Wiltshire Oct 14, 2005 #1 my passanger side drive shaft is broke!!! its makin a grindin noice think i need a new one anyone local got one spare??
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Oct 14, 2005 #2 nope, sure its the shaft at fault and not a dodgy cv or summit like that? least its the shorter (cheaper!) one. this mean the engine swap went well?
OP OP Rob_Randomcruisers.co.uk Established member Joined Jan 10, 2005 Messages 400 Points 163 Location Swindon, Wiltshire Oct 14, 2005 #3 its been running fine since da swap its just started happening, na its defo the DS as u can move it a bit at GB end
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Oct 14, 2005 #4 mmm, check its not the diff bearings. Cheers D
OP OP Rob_Randomcruisers.co.uk Established member Joined Jan 10, 2005 Messages 400 Points 163 Location Swindon, Wiltshire Oct 15, 2005 #5 ok ill get it checked
