D dillinger39 Established member Joined Nov 26, 2004 Messages 2,308 Points 469 Location manchester Oct 8, 2005 #1 i seem to be going through a brake light every six months i aint moaning but is that normal should they break after such a short time
Randomman GTI Till I die Parked in the garage Joined May 31, 2005 Messages 2,010 Points 450 Location Northampton Oct 8, 2005 #2 dillinger39 said: i seem to be going through a brake light every six months i aint moaning but is that normal should they break after such a short time Click to expand... They should last a lot longer, checked your fuses lately?
OP OP D dillinger39 Established member Joined Nov 26, 2004 Messages 2,308 Points 469 Location manchester Oct 8, 2005 #3 no i haven't should i change them all. to make sure
OP OP D dillinger39 Established member Joined Nov 26, 2004 Messages 2,308 Points 469 Location manchester Oct 8, 2005 #4 cause they aint been changed since i brought it
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,609 Points 10,657 Location Edinburgh Oct 8, 2005 #5 you want to check to make sure its the correct rating
OP OP D dillinger39 Established member Joined Nov 26, 2004 Messages 2,308 Points 469 Location manchester Oct 8, 2005 #6 ok thank you ill consult mr haynes manual tomorrow
A arseofbox Principality Retained :) Joined Jul 16, 2003 Messages 6,978 Points 1,063 Location Midlands Oct 9, 2005 #7 I had that problem...and the 1242 is about the same. All fuses in it are rated correctly but it does appear to eat the buggers...
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Oct 9, 2005 #8 LED brake lights..
T14086 Patron member Written a guide Joined Sep 12, 2004 Messages 39,858 Points 7,250 Location Preston Oct 9, 2005 #9 Whree are you buying the bulbs from? cheap ones are waste of time! *where....ooops poor spelling again
