Asteris
Member
As I already have an 1242 MPI head, fitted on my 1108 engine block, it's time to change the SPI manifold for the MPI one.
New fuel pump and rail of 4 injectors will be fitted as well as Punto 75 throttle body. This is one of the first mods done to racing centos here in Greece and i know it pushes 10-12 more HP right away (it gives 15 HP more at the 1242 engine, isn't it?)
My concern is if the standard ECU can work with this arrange, or Punto 75 ECU is needed. Electrical connections are the same between the two, even the injector wires are the same with the 4 new, only they are connected in parallel. And as they are 14 Ohms each, ECU sees the same impedance as with the single 3 Ohms one.
What I am trying to say, is that probably the 1108 ECU could be adapted to work with a MPI setup, if injection and ignition map is transfered from the 75 eprom to the 55 one. This would eliminate the need for a new ECU when a 1242 MPI engine (or the 1242 head) is fitted to a cento, only a new chip inserted to the original ECU.
1242 SPI owners could also benefit from this upgrade, if camshaft/injector rail from 75 is fitted, along with this chip installed.
If anyone has a source for more details on 1108 and 1242 maps, please inform me. If the project succeeds, i can supply these chips really cheap, less than 25 pounds or so.
