Technical Front Camber plates for cinquecento!
Glasgow
Finally, we could move away from camber bolts!
http://www.ebay.co.uk/itm/Camber-Pl...128?pt=LH_DefaultDomain_3&hash=item4ae4c63618
Great price as well!
"Pins are longer than the original pads, which allows you to mount a decent struts.
Installation on a plug & play is very simple.
On the damper is applied to the plate spring,
then the shock is applied to sleeve and further CAMBER PLATES then turns everything nut with washer.
Suitable for any suspension, which are mounted on factory pads for fiat cinquecento and seicento"
The damper bit is something i am not entirely sure about. Also will these plate just replace the existing top mounts?
Ming
I've got them on my Cinq with Avo coilovers but they are designed to fit with standard struts. I got them from their polish website, works out cheaper. No rubber bushes in them so I imagine they are probably not ideal on an everyday driver.
Will post some pics later.
I've seen these a couple of times, very well priced.
Some pics would be fantastic! Have you any idea of the range of camber that they allow?
Thanks.
Hopefully car will be back on it's wheels tomorrow so I'll take some pics of the front camber.
