super sprint sei
Member
- Jun 8, 2014
- 272
- 69
Apparent water on floor water collecting on sump. The pipes and connectors and rad are all fine
This is the third thread you've started in as many days.
Just thinking if you kept it all in one thread, we can get a better idea of diagnosing any issues you may have. Can see the history of anything you've done or any issues that you've had.
Just a thought
Genuine cheaper parts are available from - https://www.shop4parts.co.uk/
Plus if you donate to the FiatFoum you can get a discount code for 10% off.
Generally pattern parts are fine, no need to go genuine though, just trying to save you money.
Are you sure the leak is coolant, have you tasted it? Coolant is sweet. Sprinkle a little talcum powder on the block, then any fresh leaks will leave streaks in the talc and you can trace them back. Saves going all gung-ho and changing more parts and spending money when you might not have to.
