Looks like sump pan changing time. I found some rust bubbles, gave them a gentle finger prod and was treated to that lovely crunchy sound you get just before a tinworm disaster occurs.
Found a pan on fleabay for a 1.1 (I'm assuming all 1.1's share the same pan?) and some threads on here suggesting there is no actual gasket just goo from a tube. So what's the best goo to use for the job? How long should I leave it cure before topping up? Do I just wind the bolts up tight or do I need a specific torque?
Sei Sporting MPI if it makes any difference.
:slayer:
:slayer:
