Technical Heater blower electrical connection
Jaquesschitt
Rabid Rabbit
Just before I start ripping the guts out from under the bonnet< does anybody know if the electrical connector to the heater blower on a seicento can be accessed from under the dash? The bloke I got the car from says to get the blower motor spinning he fiddles around with the wiring under the dash. The fuse registers at 12 volt and is not blown and I suspect that the electrical connector may need sorting. Is he telling porkies? Can I access the motor connector wiring from under the dash? ta.
Ta, am going to have the seats out this weekend and slide under the dash. The carpet under the bonnet is coming off as well, might as well have a good go at it all. Is the dash hard to get off on these Sie's?
I would look behind the heater control facia panel first. Held on with 2 visible screws and one behind the middle control knob. Removing the dash is a very last resort and quite an involved job. The wires from the selector switch go into the heater box from behind the dash.
