Rob_Randomcruisers.co.uk Established member Joined Jan 10, 2005 Messages 400 Points 163 Location Swindon, Wiltshire Sep 24, 2005 #1 the loom thats in a 899cc how different is it to a loom in a sporting? any help would be a great help cheers rob
crayon Member Joined Feb 7, 2003 Messages 402 Points 112 Location SWANSEA, United Kingdom. Sep 26, 2005 #2 What do you need to know m8?
OP OP Rob_Randomcruisers.co.uk Established member Joined Jan 10, 2005 Messages 400 Points 163 Location Swindon, Wiltshire Sep 26, 2005 #3 i need to know what i need to put in my car to fit the sporting engine what part of the loom is different to my 899cc loom
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Sep 26, 2005 #4 If you are only putting the engine in, then you will just need the engine loom itself. Depending on comparative ages. If you want the Sporting clocks then you will need both the engine and car looms. Cheers D
OP OP Rob_Randomcruisers.co.uk Established member Joined Jan 10, 2005 Messages 400 Points 163 Location Swindon, Wiltshire Sep 26, 2005 #5 yeh the soliel is a P-reg and sporting is a R-reg and i want the clocks so looks like im gonna swap da whole loom over! god dam dash!!!!! will let u know how it goes
