mrf94
been having probs with over heating, checked all the usual things, and replaced fan switch as you do.
decided to make sure that bleeding was being done correct ,so undid pipe from carb to header tank at tank end its a long pipe so let it hang down, then noticed a lump of? goo sticking out of the plastick the pipe conects to on the tank.
ha ha found the prob, cleared it pathway into tank nice and clear now, started engine to blow through anything else in there but nothing no goo no water no nothing,removed inlet pipe to carb and the waters there but no throughput on the carb so out with the foot pump it has one of those clever little adapters for blowing up airbedsfitted same to carb in and outlets but cant blow any air or water through the carb water passages. ergo to my mind no pressure relief to header tank, so am i thinking wrong is there a? valve in there ,. i see nothing in the book that helps so is anyone out there able to shed any light on my prob ,i would be eternally gratefull,
mrf94
mrf94
