My daughter just got her sei back from the MOT and was very depressed.
It didn't appear to me to be too bad, but now I have tackled the problem I can see that it is not going too well.
1st problem is that the o/s front brakes were not working and causing the n/s froint to skid.
I had only replaced the pads about 5 months ago and when I dismantled the brakes on the n/s 1 pad was almost worn to the metal and the other was still brand new (on that side the disc was corroding because the pad was not actually pressing on it). I have replaced the pads and checked that both the caliper and the piston are moving freely. But! The n/s still skids when the brakes are applied heavily. Whether this will improve as the pads bed in I don't know.
Any suggestions would be ideal
Problem 2
The car had 12% efficency on the handbrake and apparently needs 16%. I dismantled one side at the rear and noticed that the the linkeage that passed through the backplate was seized solid, I freed this up (guess it will be better to replace at some stage) and my daughter tells me the handbrake is better, it actually stop the car on a hill which it never did before. The rain and dark defeated me when it came to the 2nd side, so tomorrow I will tackle that.
Do you think that freeing up this linkage will solve the problem, it seems a very hard thing to check without the MOT brake testing equipment.
Problem 2
