Old 15-10-2003   #1
Car won't start.
Hi. I bought a Cinq Sporting for my daughter. The problem is the car won't start. The engine turns over but nothing else. Before this the centre locking system was playing up and I don't know if this has anything to do with anything. Had a garage to call and shook his head saying he would need another guy to look at it. A cost of 800 was mentioned but not what may be the cause of the problem. Could anyone offer some help? Thanx.
medisec is offline Reply With Quote Quote
Old 15-10-2003   #2
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
What reg is it?
Hedge Seeking Missile
MrDerv is offline Reply With Quote Quote
Old 15-10-2003   #3
HP
I was only doing 80...
HP's Avatar
HP has donated!
Try the basic things first. There's a fuel cutoff switch inside the car behind the centre console mounted on the bulkhead - there's a reset switch on the top of it, try pressing it to see if it helps.
Take a plug lead off and put a nail or similar in the end, place it about 1/4 inch away from the cylinder block or cam cover, get an assistant to turn the engine over and see if you have a spark.
After prolonged cranking, is there a smell of petrol from the exhaust?
When you first turn the ignition key to position 1 (before starting the engine) can you hear the fuel pump start for 2 seconds or so then stop? (listen towards the back of the car with driver's door open)
Hope some of this helps.
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
HP is offline Reply With Quote Quote
Old 20-10-2003   #4
Many thanks for your help. Called a garage out to fix it (with any luck). I'll let you know the result.B)
(T) Seicento SX 2001 won't start dimension3 Cinquecento / Seicento 12 27-11-2008 09:45
(T) Tipo doesn't start after idle feil Tipo (Classic) 4 28-04-2004 19:35
(T) Hot start - no go!! J9 Cinquecento / Seicento 5 05-01-2004 01:11
(T) Cold Start spray fixed it . How ? Oilslick Punto (Mk1) 5 02-12-2003 04:05
(T) 83 SPIDER WON'T START TEXASTOUGHFIAT 124 Spider (Classic) 2 20-06-2003 05:14
