Old 31-07-2005   #1
Trader Rating: 1
EvilJaxx has donated!
Throttle lag
Hey guys,
As the title suggest's I am having some issues with the accelerator , ever since I got back from my Holiday I am having some issues with a small lag on the pedal.
For example if I hold 2nd to 3000 rpm and then flaw the pedal about 0.5 seconds later the engine responds pushing me into the seat, now this is very frustrating because when you leave 2rd reving to say 4800 rpm and put it in 3rd and flaw the throttle again it does the same thing between gears so this loses alot of time to 60 and means getting the bite right is all funny due to not being able to set the right revs
At the moment the pedal is abit stiff when I dont use the car much so tomorrow i am gonna WD40 it and hope its that... But im doubtful, maybe the cable is stretched???? or at worse something wrong with the fuel injection system?
What you guys think
Adam
EvilJaxx is offline Reply With Quote Quote
Old 31-07-2005   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: Throttle lag
sounds like you are describing a hesitation rather than a sticky cable.
Old 31-07-2005   #3
Trader Rating: 1
Re: Throttle lag
No definatly not me hesistating I am driving how i always drive but there is some lag which has appeared.. I guess you could call it a flat spot almost where the engine wont respond for a few seconds its very annoying!
Old 31-07-2005   #4
custard's Avatar
Trader Rating: 1
Re: Throttle lag
um i meant the engine hesitating not you lol
Old 31-07-2005   #5
Chris
Trader Rating: 2
Bushboy has donated!
Re: Throttle lag
turn the throttle at the throttle body and see if it still lags. might be the engine
Hi!
Bushboy is offline Reply With Quote Quote
Old 31-07-2005   #6
Trader Rating: 1
Re: Throttle lag
sorted it WD40'ed the pedal hindge and also oiled the cable and feels so much smoother how was i driving this car before I say to myself....
also the cable was rubbing against the stuppid K&N oil breather pipe causing the issue just turned the pipe abit and sorted!
Old 09-08-2005   #7
Trader Rating: 1
Re: Throttle lag
Maybe not, problem came back and I still sat and blamed the Bosch Super 4's, so went and got some Champion EON 2's today and some Waynesnjector cleaner and it seems to of knocked the issue on the head again So it seems the Bosch Super 4's where the issue as the cleaner wont work right away!
Old 09-08-2005   #8
arc
this is where i stand
arc has donated!
Re: Throttle lag
i have trouble with the breather hitting the throttle cable sometimes too. But yeah, super 4's are rubbish..
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 10-08-2005   #9
Trader Rating: 1
Re: Throttle lag
Anyone want a set of Super 4's for 5 as I have no use for them now!
Edit: Used for about 1 week basically brand new!
Old 10-08-2005   #10
arc
arc has donated!
Re: Throttle lag
totally off topic, just noticed you are in Chester. I've got friends there and am around quite often. I'll have to keep an eye for you!
(T) Special made throttle body for Cinq/Sei + Punto 55/60/75 Tricker... Cinquecento / Seicento 32 14-05-2012 21:18
(T) Punto 75 Throttle Body DJ_Bucho Cinquecento / Seicento 65 26-04-2011 13:43
(T) Sei mpi throttle bodies. J.R Racing Cinquecento / Seicento 6 29-04-2005 23:52
(T) Enlarged throttle body for Punto 75 (from 38mm to 43mm) Tricker... Punto (Mk2/2b) 0 21-02-2005 18:39
(T) Squeaking when cornering dunkv Tipo (Classic) 8 09-01-2005 12:51
