Thread Tools
Old 28-07-2005   #1
Angry Chinq 899cc (1998) Stuck in 4th Gear
Seems to be stuck in 4th Gear, Will not Start unless you put the Clutch to the floor, and then as you release the clutch the car starts off in 4th Gear and the gearstick will not shift an inch !
Pulled the shroud off from around gearstick but all seems to be ok, 2 rods all connected fine but just no movement.
Dont think this is Clutch related.........!
Advise would be really aprreciated !
(Car has only covered 24000 miles since new in 1998 !!!!!) it is immaculate and it seems a shame to scrap the little fighter !
Andrewalbr is offline Reply With Quote Quote
Old 28-07-2005   #2
arc
this is where i stand
arc has donated!
Re: Chinq 899cc (1998) Stuck in 4th Gear
does it shift with the engine off? im guessing not, i suspect its not a clutch problem as you dont need a clutch to shift with the engine off (unless ur on a hill i suppose)
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 28-07-2005   #3
It Doesn't shift with the engine off either !
Tried driving it around the block earlier and it wont budge even whilst in motion !
Old 28-07-2005   #4
arc
arc has donated!
i dont know anything about the inside of them gearboxs, but it does sound like something has broken/bent in there
Thread Tools
(T) Abarth stuck in gear jonnyk Stilo 60 22-10-2007 19:19
(T) stuck in gear.. kippax53 Cinquecento / Seicento 4 27-07-2005 22:37
