Old 30-09-2014   #1
Hand brake
Hi, my cinquecento's handbrake is on the last click could anyone tell me how to go about sorting it out. Many thanks
cookie88 is offline Reply With Quote Quote
Old 30-09-2014   #2
Re: Hand brake
Generally cento handbrakes are crappy anyways but try strip clean grease and adjust of rear shoes.
Jd801 is offline Reply With Quote Quote
Old 30-09-2014   #3
Trader Rating: 5
fingers99 has donated!
Re: Hand brake
Adjustment is under he car, in front of the petrol tank.
Most important thing is to make sure the shoes still have 3mm + of meat on them and that the adjuster "elbows" have not seized up.
Exploded diagrams in the Seicento Technical Manual (Downloads) -- same basic brake system, but adjustment is different. Haynes is fairly useful, too.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 30-09-2014   #4
Ireland
Re: Hand brake
As the others have said free up the handbrake elbows and put copper grease on the joints. Then adjust the cable. Got 25% on most recent NCT test (Irish mot) best ever for a cinq. Shoes need to be perfect.
moss899 is offline Reply With Quote Quote
Old 30-09-2014   #5
Re: Hand brake
Thanks for the onfo lads, appreciate it!
Old 01-10-2014   #6
David C has donated!
Re: Hand brake
Also, take the drums off and lever the shoes out on their friction adjusters until the drum only just clears.
Cinq handbrakes don't have to be rubbish.
Properly adjusted they will impress your MOT man.
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is offline Reply With Quote Quote
Old 02-10-2014   #7
Re: Hand brake
Haha thanks il have a look
Old 02-10-2014   #8
Young Efficient has donated!
Re: Hand brake
When I first got my car, the handbrake was so bad, you could get up to 50. But underneath there is a an adjuster. Gotta be skinny to get under.
http://s.fiatcdn.com/signaturepics/sigpic148429_1.gif
899cc 1.4l White Night and Day Cinq.
1.1l Red Seicento Sporting MPI
Young Efficient is offline Reply With Quote Quote
Old 03-10-2014   #9
Re: Hand brake
Yeah I have been under (had to jack up as im deffo not skinny) and it's maxed out
Old 03-10-2014   #10
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Re: Hand brake
in that case its 99% going to be seized actuators at the back - to get them off you need to drop the drum off so while you are there check condition of drums and shoes. Have a check that hte wheel cylinders are not weeping as well while your there.
New actuators are not expensive but its only a little bit of work to clean them up and lube them with some copper slip or silicone grease.
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 03-10-2014   #11
Re: Hand brake
If (or rather: "when") you replace the handbrake cable, spend some time running some engine oil inside the cable until it drips out of the other end.
Makes a nice difference to how the handbrake feels and will keep it working well too.
Most garages will never do that as it takes too long.
Likes Eklipze3k liked this post
Old 05-10-2014   #12
HP
I was only doing 80...
HP's Avatar
HP has donated!
Re: Hand brake
Cable was greased and new, should be ok - as were the rear links. You can take up adjustment by moving the handbrake lever itself - look under the carpet and it's held down with 4 x M8 (13mm socket) bolts. Slide it forward to tighten things up.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 05-10-2014   #13
Re: Hand brake
Cheers mate!
(G) hand brake fender mender Stilo 1 11-09-2011 16:46
(T) hand brake charlieann Punto (Mk2/2b) 4 30-10-2010 16:26
(T) hand brake billy the bodger X1/9 3 06-03-2010 23:21
(G) Hand brake madmoose2009 Cinquecento / Seicento 3 23-06-2009 16:17
(T) Hand Brake jaque Cinquecento / Seicento 4 17-03-2004 09:39
