Old 19-07-2005   #1
arc
this is where i stand
arc has donated!
Rear disc conversion
I am unlikely to do this as I don't have any money, although i am interested in what needs to be done, how and where to get bits from. I would like to see this thread become a nice collection of knowledge on what needs to be done.. although i know nothing on the subject really so can't help much.
Anyone start the ball rolling, what calipers.. cinq std front ones? Same deal with the discs.
Does it need something to distriubte braking power properly?
Ive no idea!
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 19-07-2005   #2
Chris
Trader Rating: 2
Bushboy has donated!
Re: Rear disc conversion
how does the handbrake cable connet upto the calipers with this done?
I know teressa (1.4 cinqi) has it done so maybe she can shed some light on the subject
Hi!
Bushboy is offline Reply With Quote Quote
Old 19-07-2005   #3
Cornish Cinque
AIJ29's Avatar
AIJ29 has donated!
Hi
You`d have to get some rear calipers from another car maybe punto gt or uno turbo as these are already made with a handbrake take off,the punto gt uses the same discs on the rear as the cinq does on the front,
Rallycinq has rear discs and he`s using 13" wheels,
Adrian
AIJ29 is offline Reply With Quote Quote
Old 19-07-2005   #4
Funny saying here
jamie86's Avatar
Trader Rating: 1
jamie86 has donated!
I'm sure he also said somewhere he had to get spacers made up...
Tbh i don't see it would actually be that much work looking at it....
Quote Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline Reply With Quote Quote
Old 19-07-2005   #5
Cornish Cinque
AIJ29's Avatar
AIJ29 has donated!
Jamie
I think the spacers he had made are for his front brake conversion to position the uno turbo disc so it would run in the caliper correctly,
Adrian
Old 19-07-2005   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Rear Brakes
Cinq front discs, Punto GT rear calipers, Small modification to handbrake cable, mounting brackets require fabricated.
D
Old 19-07-2005   #7
Funny saying here
jamie86's Avatar
Trader Rating: 1
Uno ones could also fit then?
Old 19-07-2005   #8
Cornish Cinque
AIJ29's Avatar
AIJ29 has donated!
Quote Originally Posted by rallycinq
Rear Brakes
D
Hi Rallycinq
Any pictures of the mounting brackets? or the complete conversion?
Adrian
P.s any changes to brake bias valve or servo/master cylinder?
Old 19-07-2005   #9
nippy little runt
microcar's Avatar
microcar has donated!
ummm, is it worth the bother for a rear brake conversion? do you need to have super stopping power?
97 1.1 Sporting Gas Flowed and Ported head, Fast Road Cam, Induction Kit. 14" Punto Sporting Alloys. Chip. Alloy Rad. Remus stainless steel exhaust.
microcar is offline Reply With Quote Quote
Old 19-07-2005   #10
Banned
darkcircuitUK's Avatar
darkcircuitUK has donated!
darkcircuitUK is offline Reply With Quote Quote
Old 19-07-2005   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by AIJ29
Hi Rallycinq
Adrian
No piccies at the mo, car away being worked on.
I have a balance bar assembly, but it worked OK ish with the standard set up.
D
Old 19-07-2005   #12
Hmm i am very interested in this too, i was discussing it with arc the other day. I wanna put Punto GT disks etc on the front so i'll have spare Sei calipers etc. I am guessing a full set of Sei front calipers and disks are fine to use. The hang-ups i had were the handbrake and if a balancing unit was needed.
GeX is offline Reply With Quote Quote
Old 19-07-2005   #13
Greece
Ok, here's the deal for rear disk conversion on a cento.
Calipers from Uno turbo/Punto Gt (they are the same)
Plate from Uno turbo, fits straight
Disk 228mm from Uno turbo
Hub from Uno turbo
Straight fit, no modifications needed, cento handbrake cable mounts with no problem.
You can also use the 240mm disk (cento's front, Punto GT rear, Alfa 155 rear etc), with same calipers and without changing hub, if you fabricate a custom plate based on the Uno's plate, only the two holes the caliper mounts on have to be 6mm further out.
I have them almost a year now, no probs with the handbrake, no better stopping power, but you can break inside a turn without fearing for the weels to lock unexpectedly. Oh, and far better looks of course...
Asteris is offline Reply With Quote Quote
Old 19-07-2005   #14
Autotest Special
rallycinq's Avatar
Trader Rating: 1
You can't use the Sei front calipers on the rear, they have no handbrake facility.
D
Old 19-07-2005   #15
HP
I was only doing 80...
HP's Avatar
HP has donated!
Do you need to reduce the fluid pressure to the rear disc brake calipers if you do this?
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
(S) Updated price list 21/04/2004 Body Stylist Punto (Mk1) 30 09-04-2005 17:02
(G) DJ Bucho is back DJ_Bucho Cinquecento / Seicento 19 14-05-2004 18:41
