I've been looking at getting my ECU remapped. It seems I'm looking at spending between €500-800 and will then be stuck if I want to do any further mods. ITB's on the to-do list as I've been given a set of four including injectors but that's besides the point.
A colleague of mine happens to have a dyno in his shop and a dealer in his neighbourhood carries the Det3 as well as a bunch of other goodies.
Would it not make most sense to go Det3 piggyback on my SPI engine for now, considering the before-mentioned pricing on a remap?
Once the ITB manifold is done it should then be sort of simple to get that mod up and running.
It appears I have access to all the support I need (machining, welding, RR, any material from sheet metal to 100mm blocks of aluminium etc.) and cheap, too.
