Hi guys!
There doesn't seem to be much information regarding this kind of swap. Most of what I've seen is either people fitting 16V engines, or P75 engines to SPI cars.
I reckon that, from what I've seen in my car and the donor parts I have, it should be pretty straight forward. However, I've got a few questions about a few bits and bobs, that were raised when I looked up some of the swaps here in the forum, as well as that great guide for the 1.4 swap
So, first of all, here's what I have. The car is a Seicento S, but it's an MPI version, so a 1.1. It has the older (uno-style, I believe) gearbox with the long driveshafts and inner cups. No power steering, AC, electric windows or any other "extra" stuff in this car.
The donor parts are a huge mix of things I collected in my garage throughout the years. For the engine block, I have a PMK2 60 engine block to go in, it still has the original head in it, albeit cracked, would still work for a cento. I also have a spare P75 head laying around with no anciliaries, and in much better condition, so this will be used. A donor gearbox off a Seicento Sporting, and driveshafts off an SPI Seicento Sporting as well.
The main idea here is, for now, to swap the engine with OE anciliaries, and replace the gearbox with the better one from the Sporting. Then build it up from there, with the engine already running and in the car. But a few questions arise, mostly due to the fact that my Sei is not a Sporting to start with.
1. Do the Sporting driveshafts fit the hubs on a standard Sei?
2. Does the standard Sei gearbox lower mount also fit the Sporting gearbox, or should I be looking out to buy a new one?
3. Will the Punto MK2 exhaust manifold fit between the engine and radiator? The catalytic converter is MASSIVE! I reckon this will be needed due to the fact that the Sei manifold is shorter in height (10mm) and should not clear near the sump. It's also a bit more restrictive. A plus is that I want to use aftermarket punto exhaust manifold at a later point in time, so I can have the exhaust system made to order meanwhile.
4. Will the Punto clutch/flywheel fit OK? I reckon it's the same size as the cento, however the part number is different. Maybe the flywheel changes as well?
5. Will the alternator from the Sei fit the 1.2 as a straight swap? I know this is an issue with the 1.4 swap on SPI centos, from the guide, but since the 1.2 8V engine is different... I remember it was even an issue when I swapped my Punto, the 8V alternator had to be spaced out to fit by a couple milimeters.
6. Last but not least, will the harmonic damper from the Punto work? Or if I fit the Sei harmonic damper, will it be a straight swap (i.e. align with the camshaft VR sensor properly)? Not looking forward for oil pump swaps...
7. Bonus question: Is the Grande Punto 1.4 8V MLS headgasket a good swap for the 1.2? From what I've seen, it should fit, measurements look to be about the same, but I don't see anyone talking about it, so maybe it doesn't?
If you guys know the answer to any of these questions, I'd be greatly appreciated. Considering making a guide for this kind of swap afterwards, so people will not have to ask the same questions I did
