I have recently changed the water pump and radiator on my seicento. Everything went ok and I thought I had bled the system properly, but the car still seems to be using coolant.
I can't see any leaks anywhere and there is no tell tale signs of the head gasket going.
I went and bled the system again, this time I noticed that when I rev the engine I get a nice steady stream of coolant coming from both bleed valves, but when I let the engine drop back down to idle, the coolant seems to get 'sucked' back down the pipe.
Is this normal or is there still some air left in the system?
Any help would be appreciated
