Technical Charcoal Canister Armature????
Northampton
Ok, cut a long story short, Cinque had a front end bump before I got it, knew all about it, no major problem.
The other day I noticed that the charcoal canister was low, REALLY low, after checking everything I decided its as secure as it has ever been, I must have just been less astute before.
I have checked under the little lass (car) and seen that there was another hole in the frame for mounting it, so I guess it was moved in post-crash repairs. No problems, but I worry when going over speed bumps moreso now (its the lowest part of my car, cept wheels!) And if I ever did want to get the lass lowered in future, Its gonna be a problem, so I may as well get it sorted now.
But whats it called!? I'm going to a scrappy at the weekend (also for some wheel arches) and I need to know its real name! Also, does anyone have one spare at all?
Many thanks
rallycinq said:
Charcoal canister would do it for me.
D
The arm bit attaching it to the frame?
I fear I may have to show him, must remember to measure mine to make sure its the size, not the positioning!
Thanks for a fast response
Hi
Try to find a scrapyard that lets you walk around,they are out there,chances are the bits will be cheaper and you never know what else you might find worth buying
Adrian
