M Michael1973 New member Joined Jun 24, 2013 Messages 93 Points 43 Mar 24, 2014 #1 It it easy to adjust my headlights one of them is way out (no crash damage this happend when I changed bulb)
OP OP M Michael1973 New member Joined Jun 24, 2013 Messages 93 Points 43 Mar 24, 2014 #2 By the way it's a 03 seicento.
Jd801 New member Joined Sep 30, 2013 Messages 150 Points 39 Location Norwich Mar 24, 2014 #3 If it happened when you changed the bulb have you check to make sure it's fitted right?
David C Patron member Joined Mar 29, 2005 Messages 1,787 Points 399 Location London Mar 24, 2014 #4 Jd801 said: If it happened when you changed the bulb have you check to make sure it's fitted right? Click to expand... Exactly... OR it was fitted wrong before and adjusted to suit and now with it fitted right needs adjusting back to the right place. Adjusters usually on the back of the lights (there will be up/down and left/right adjusters)
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Mar 25, 2014 #5 Or the headlamp itself is broken -- if you can freely waggle around the bulb (hold it by the connector) this confirms. There is a thread with a fix.
