im Axle Specialists
Thread Tools
Old 25-01-2014   #1
Barchettista
NSMG has donated!
Portugal
Post Headliner Removal
Cheers,
I need to remove my cinq's headliner to install a new roof antenna.
Just had a look in the workshop manual but still have a few questions :
1) Is it really necessary a clip tool to remove the plastic clips that hold the headliner ?
2) Is the headliner also glued to the car roof ?
3) Is it necessary to lift the windows rubber mouldings to free the headliner ?
Thank you.
NSMG is offline Reply With Quote Quote
Old 25-01-2014   #2
Flat Out!
Cento186's Avatar
Cento186 has donated!
Re: Headliner Removal
I'm not sure about the clips or anything but when I fitted a new aerial to my Seicento all I did was removed the interior light and pulled the headlining down in the centre where it reaches the windscreen.
It was pretty awkward to do and you have to be careful not to damage/bend the headlining too much.
Cento186 is offline Reply With Quote Quote
Old 25-01-2014   #3
Trader Rating: 5
fingers99 has donated!
I can't remember unclipping anything. Use the old cable as a fish, don't use a halfords antenna -- the cable is too short, so you need to buy an extension!
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 26-01-2014   #4
Moderator
jatkinson is part of the official FF Events Team :)
jatkinson has donated!
i just took the Two sun visors off , the plastic "jesus" handel , and the black caps on the drivers side , and pull it down this gives you enough room to access it
jatkinson is offline Reply With Quote Quote
Old 26-01-2014   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
I think I did mine through the interior light hole....but I haven't had a headcloth in the car for years.
D
Thread Tools
(S) Sagging headliner aurick86 Bravo 3 21-10-2013 14:14
(T) Engine Removal - Gearbox linkage and Air Con removal stilotoby Stilo 5 26-11-2010 20:29
(G) Headliner & C pillar :( Brin Punto (Mk2/2b) 3 06-09-2010 09:07
(G) How to cure a sagging headliner for good! JimMagill Panda (Classic) 27 29-04-2008 19:10
(T) removing the headliner Big Black Stilo Stilo 15 23-07-2006 21:23
