Well the ones on my Sei are pretty good with normal E approved halogen bulbs.
You may need to dismantle and clean yours my fogs were so ineffective I took them off as I could not clean them internally and the clean dipped beams just cut through fog.
Note I have told the broker.
Quite apart from dazzling people some of whom may react in kind with main beam and driving lamps - if you just swap bulbs and if you get stopped and they detect lots of delinquency they will tot up the points.
It is easy to detect non E headlights.
Im seeing more people stopped than ever before.
If your head lamps are dangerously dim either drive slower or fix them proper.
What did you tell the broker?
Did you tell them you are essentially modding your front bumper because now it has either 2 hole in it and two cover plates. That's a styling mod.
As the weight of the car has now decreased, this is now a performance mod.
Aerodynamic of the car will also have changed, as air could flow through the two holes. This is a styling and performance mod.
As you say, if not they may not pay out.
Ming
