had a spare set of LED bulbs kicking around so threw them in the brake / tail lights and all was well at first as one of mine had blown - old bulb tbh.
But now i get some funky behaviour
Now when the boot is closed I have working brake lights but the side lights stay off.
When you open the boot both side and brake lights work.
When the boot is closed only the centre high level brake light illuminates until you hit the brake pedal at which point all the brake lights come on but still no rear sidelights.
Is this just a weird fault with LED lights and incorrect resistance being thrown into the earth circuit? I presume that going back to standard filament bulbs will cure the 'fault'?
