Technical 900cc Cinquecento swap 1.2 8v ?
Natou12
Hi guys,
Could anyone tell me if a 900cc cinquecento will accept a 1.2 8v swap also with the punto gearbox ?
Is it as simple as swapping to a 1.1 sporting cinquecento ?
Engine mounts, parts needed etc...
I'll might be on the way to get my second Giannini if yes...
Thats it ? So the 900cc + the 1.2 8v engine + all that list and its good to go ?
Im waiting for every one to go , "just buy a sporting it will be easyer blah blah blah"
both me and ming have had 899 running 1.2 8vs ,
buy the 1.2 8v with gbox ,
Sporting driveshafts
Gear selectors
to get the 899 loom working on the 1.2 , think you need to extend the oil pressure sender wire , and the Tps sender ( ycming will confirm)
Gear selectors
Thanks mate, do you have a thread with your 900cc conversation ? I have never done any swap, first time for me, mechanic beginner, so will need help...
It's a pretty simple swap
Other than what others have suggested you also need the engine mounts off a sporting. The parts that bolt to the chassis legs.
I ran mine for a couple of days with an 899 ecu. Didn't notice any difference to using a sporting one but probably was under fuelling a little
Take loads of pictures and do a guide. People (myself included) will always want to know what's needed to change it and would be great to have it in one thread. I meant to do one myself but time pressures meant I had to get it done quickly and didn't have chance to take photos.
The wiring changes are obvious once the engine is in place. If you're lucky your 899 will have a removable engine loom like the sportings, then you can just swap them over. I did an engine swap in an sx years ago where that was the case.
Hi guys. (sorry my english not good :/)
how to connect 899 wiring loom to 1.2 8V, Injection vs carburetor.
thanks
