Thread Tools
Old 23-09-2003   #1
Rear brake lights problem
Hi all,
I've just bought a '97(R) Cinquecento Sporting and noticed this morning that the rear brake lights aren't working.
I was thinking it could be a simple thing like the bulbs but as they are both gone could it be the fuse? Where is the fuse box by the way? :)
I just want to cover everything before I check it out at home tonight.
Thanks in advance,
Ricky
Bois_aiii is offline Reply With Quote Quote
Old 23-09-2003   #2
HP
I was only doing 80...
HP's Avatar
HP has donated!
Hi, and welcome to the Fiat Forum.
The fusebox is under the steering column, kinda between your knees when you're driving. Comforting thought should you have an electrical fire:I:D
Could also be the switch - this is mounted on the pedal box under the dash. Connect both wires from this together to check, the lights should go on.
If your fuse has gone, the reverse lights and clock should pack in too. I had this a few years back due to a bulb that was made badly and shorted internally!
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
HP is offline Reply With Quote Quote
Old 23-09-2003   #3
Ok great, thanks so much for the help.
From what you tell me, it could either be the switch or the bulbs, as the clock and reverse lights are working. If the switch has gone is it a bugger to replace?
Thanks again!
Old 24-09-2003   #4
HP
HP's Avatar
HP has donated!
Don't think so, just a question of getting your head under the dash to get at it:)
Pete.
Clubcento
Old 24-09-2003   #5
Hi
I've just sorted it. It was just 2 blown bulbs. Lucky this time!
Thanks for your help,
Ricky
Thread Tools
(S) Updated price list 21/04/2004 Body Stylist Punto (Mk1) 30 09-04-2005 18:02
(T) Rear Brake Lights Jeffers Punto (Mk2/2b) 6 30-05-2004 00:58
(S) rear brake lights hoyley_boyley Bravo / Brava 1 17-01-2004 01:07
(G) Brake light problem - help! Surrey Sporting Panda (Classic) 8 01-07-2003 03:23
(S) HGT Hand Brake & Rear Lights Ceggy Punto (Mk2/2b) 1 24-04-2003 02:28
