CinqoSX
Im new here, and hope i can get my answers here.
I bought my cinq SX (96 N reg, 899cc) and the guy who owned it before said he couldnt get it to go over 65mph. After buying and giving it a service (oil change, spark plugs changed, air filter changed) it seemed to solve this and the car has been running extremely well. The only other thing I've had to do is change the front shock absorbers and replace a tyre.. apart from this the car was faultless.
However, it seems to be leaking a lot of engine oil now, and it leaks when its running a little, but also a lot when it is parked up and cools down. My girlfriends dad is the one with the engine know how, and says that the gasket and sump covers need replaced, and maybe possibly the crank shaft seal (possibly), but is there anything else that may be causing this leaking?
Anyone else had any problems like this or know how to solve this? This seems to be the only problem with it, other than a dodgy rear shock which i will replace myself this afternoon.
Thanks in advance!
EDIT
I should have mentioned that he also said it could have something to do with the gearbox, even though hes certain its engine oil, because its dripping along a bracket underneath the car, and the gearbox makes a squeal when you first start driving and whenever i reverse
Thanks in advance!
EDIT
