Tuning 16v cinq wont rev above 4500
i will be getting the smaller one that goes inside its just easier
il have to check the ecu for faults tomorrow it had some stored from before
when i had injector trouble
so ive cleared them then ran it for a few mins at idle few times revving it up til it splutters so i have an idea of whats wrong
if theres no faults
then its gonna be fuel (this cannot be scanned for faults obviously , apart from injectors)
I did't need this in mine. But I have got this from reddy if you want to fool the punto mk1 16v ecu.
To quote "It is just a resister which appears to the ecu as a valve. For a some seconds the resistor will be energised and giving off 5 Watts of heat, ecu then turns it off for duration of journey. Easily fitted externally to ecu."
Ming
