Old 11-09-2013   #16
Trader Rating: 5
fingers99 has donated!
Re: Good petrol? Bad petrol? (for a 2001 Sporting model)
I use 99 octane in my turbos, too.
Now I remember, 5th Gear did do some dynamometer tests of various fuels, which may be on the Net somewhere. Essentially they found that engines designed for 95 octane made no more power on 99 octane than on 95, while (some) engines designed for higher octane fuels would run on 95, but lost power on the cheap stuff. (Don't try this on cars where the ECU is unable to adjust the ignition timing to compensate, or mahem will occur.) From memory, they used a late Imprezza (it would destroy an early one) and something awefully posh.
Although associated with performance, high octane fuels are actually slower burning than low octane ones. This becomes very apparent with super high octane fuels like Methanol, Ethanol and LPG which require a lot of ignition advance to get peak combustion at more or less the right time.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 11-09-2013   #17
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Quote Originally Posted by fingers99 View Post
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 12-09-2013   #18
Trader Rating: 5
Or .
M12 fund 20
Old 12-09-2013   #19
David C has donated!
All standard (and by "standard" I mean unmodified) Cinqs & Seis should run perfectly on 95RON and show no improvement on 99RON (and could possibly run worse as they have no knock sensors).
However I suspect the ignition timing is slightly out on my 899 Cinq and that combined with the slightly higher compression ratio from needing the head skimmed means I get pinking on 95RON but it runs perfectly on 99RON (Tesco 99 most of the time).
I know I should just adjust the ignition timing, but I suspect the screws will snap and just using 99RON is a lot less painful...!
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is offline Reply With Quote Quote
Old 12-09-2013   #20
Trader Rating: 3
ycming has donated!
Quote Originally Posted by David C View Post
Is that possible (adjusting the ignition timing) on an 899?
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 12-09-2013   #21
Quote Originally Posted by ycming View Post
not easy e.g. move the TDC sensor...
but he should not be pinking after a skim even on 5% ethanol cut petrol, may be bad headgasket?
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 12-09-2013   #22
But it's hardly a double blind test, therefore has no objective relevance. Indeed, I know of no objective tests which prove any performance increase with vehicles designed for 95 octane. (And you'd certainly expect to see them!)
Sorry to pee on your delusion!
I don't think that I was claiming anything other than subjective impression , consequently am bemused by your attitude .
But ultimately couldn't give a monkey's , frankly .
Recreate the thrill of the dodgems by strapping a fishing rod to a Cento and driving the wrong way round the M25.
dr pinkie is offline Reply With Quote Quote
Old 12-09-2013   #23
Quote Originally Posted by dr pinkie View Post
Er - sorry to rain on anybody's parade , but I have run both my present 2000 Sei and previous Chinc (and previous Honda nx650 'bike) on super only , Tesco 99 for preference , except when not available , and you certainly can tell the difference in terms of throttle position , sprightliness , and ability to climb hills .
Just sayin'
don't see the word subjective or opine?
Old 12-09-2013   #24
Trader Rating: 5
Some kind of petrol head Creationist, perhaps?
Thanks Pep0 thanked for this post
Likes Cinq999 liked this post
M12 fund 20
Old 14-09-2013   #25
Suggest you two keyboard heroes re-read the second line of my reply for true enlightenment .
Old 14-09-2013   #26
Trader Rating: 5
What's that
Quote Quote:
Just sayin'
or
Quote Quote:
M12 fund 20
Old 14-09-2013   #27
All I can add is that the one time I accidentally put Shell V Power in the Sei I got the highest mileage I've ever got out of a single tank - 362 miles. However even if this was repeatable, the increase in MPG would be entirely negated by the higher cost....
As I'm a bit sad I do actually keep detailed MPG records, over about 30K miles we have averaged 41mpg. It continues to creep up slightly as I am doing more motorway driving now, the car is the closest to being "new" that it has been since it was, well, new, and for the first month we had it the tank was leaking.
45mpg seems like a reasonable figure for a well maintained standard Sporting.
Spannerism is offline Reply With Quote Quote
Old 14-09-2013   #28
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
45 seems ok for normal ish driving, a cento can do much better though although i find it really hard to drive one in an economical way.. Also i have even even been in a mpi one let alone run one for a bit so can't comment there, and nor do i ever really keep track of how much i use personally - but i do know that my cinq over the stanford hall weekend did about 350 ish miles on 1 tank of regular fuel even though it wasn't running well for alot of the time. But I have a P60 engine in that so not really a fair comparison either.
Old 16-09-2013   #29
The Ratter
slugworth1987's Avatar
slugworth1987 has donated!
899 made no difference
1.2 16v - high octain higher mpg and a few flames standard octain less mpg and no popping/flames
Likes homeward liked this post
-Slugworth1987
Wanted:- Fiat Uno Wiper motor with arm
slugworth1987 is offline Reply With Quote Quote
Old 16-09-2013   #30
Brain stopped play
homeward's Avatar
Trader Rating: 1
homeward is part of the official FF Events Team :)
homeward has donated!
Quote Originally Posted by slugworth1987 View Post
Sadly/thankfully, I don't get any flames from my Punto...
...but I certainly get better economy (fewer pence per mile, as well as higher miles per gallon) with super unleaded (as I've said elsewhere... -- sounding like a broken record...).
1990 Panda 750L Formula '90: Pippin (26,131 miles; 47.18 mpg)
2009 Panda 1.2 Eleganza Dualogic: Pandora (55,670 miles; 47.87 mpg)
2002 Punto 1.2 16v ELX Speedgear: Priscilla (100,465 miles; 41.30 mpg)
homeward is offline Reply With Quote Quote
(T) CV boot replacement - 2001 petrol model Roger Bruce Multipla 0 16-04-2013 16:01
(T) total loss of power on 1.2 petrol doblo 2004 model deuwins Doblo 1 06-10-2010 07:45
(T) Stilo cuts out 1.6 petrol 02 model justy22 Stilo 15 04-03-2010 16:00
(T) JTD model - petrol in empty tank beeso1974 Multipla 5 26-01-2009 21:48
(T) Cinquecento 899cc 1996 Model - Petrol Gushing out! Psytek Cinquecento / Seicento 6 03-01-2007 11:29
