Seamusoceanainn
- Aug 27, 2013
- 6
- 2
A newbie here,
I'm driving an 01 sei with the 898cc engine and the fan belt snapped over the weekend (which happens every 6 months or so to me). When the water temp warning light came on I pulled over immediately, but steam/white smoke started to billow out from the bonnet and the coolant was boiling when I pulled the bonnet. After towing the car home, replacing the fan belt and topping up the coolant levels (which was only half empty), the water temp light comes on after ten minutes driving. Heaters work fine and keep blowing hot air, so I think it might be the head gasket gone, but I'm not sure. Does anyone have any advice on what else could be the problem or how to make sure it is the gasket that's gone before I set about replacing it? Thanks.
