Styling Side skirts
Styling Side skirts
Michael1973
I've just glued my side skirts on with polyurethane glue (pu18) got some on paint work what do I use to clean it of sticky as fook help.
Toffee wheel
http://www.ebay.co.uk/itm/Automotive-Toffee-Whizzy-Stripe-Removal-Wheel-/350329202253
Just be careful you, need to move the toffee wheel about or else it will heat and burn the paint. If youve never used one before have a practice on something else.
There fantastic, but in the wrong hands, awful.
While the PU is still wet, you can remove it with acetone, panel wipe, etc.
The big caution is that although that'll work fine on old factory paint or 2pac, the solvent will tend to remove rattle can paint.
Body shops will generally glue panels on and then paint, but this can cause real issues is the paint doesn't quite match and if you're not very skilled.
