tomandsophie
- Jun 6, 2005
- 50
- 17
I think my MAP sensor's on its way out (engine gives massive hesitation, mostly under gentle acceleration but often when just cruising along). I've checked the vacuum hose and put a new one on so I know that's not the problem. I've heard there's a way you can check the MAP sensor by disconnecting the end of the hose from the engine and sucking through it and the revs should rise. Well, I tried that and the revs stayed the same - if I sucked really really hard then the revs would occassionally blip up a little bit. However, if I blew through it I could make the revs rise.
Any ideas?
Any ideas?
