The handbrake light on my sei sporting has got into a tendency of flashing on and off under hard acceleration, and when the engine gets to high revs it stays on permanently as soon as you shift into the next gear it goes out, until the revs build again, its basically acting as a shift light, apart from in 5th where it doesn't come on at all not even at 5500rpm! I am guessing this is a loose connection how would you access the switch, from underneath the car? Any help to fix would be most appreciated although i will miss my lil shift light!! I would appreciate a reply although i bet a lot of you are polishing and busy getting your beauties ready for stanford!!
