- Oct 18, 2012
- 18
- 7
I am fitting a new radio/cd to my sei. It requires a 12v Yellow direct feed and a 12v switched Red supply from the ACC on ignition switch. As there is no ACC on my ignition, I will fit a toggle switch somewhere on my dashboard, it will be fed from the constant 12v supply from the input side of the hazard warning light switch in the center of the switch cluster. I do not want the radio to have a constant live supply by joining the red and yellow wires together. The output side of the toggle switch will supply a 12v feed to the red input on the radio. Basically the toggle switch is standing in for the non existent ACC on the ignition. The reason I want to do this is I wish to use the radio/cd when parked without the engine running. I also wish to switch of the RED feed when radio is not being used. If anyone knows another easy way of doing this I will be happy to listen. My question is ! how to access the rear of the hazard switch, does it just pull out of the cluster, it is the round type as in fig 46 of the owners guide. I hope this all makes sense.
Mike.
Mike.
