My Sei 1.1 sporting has recently had a recon head, gaskets and thermostat fitted. All seemed good but I've noticed I'm losing a small amount of water from the header tank when I check it weekly. Yesterday after topping up I left the car to run up to temp and for the fan to cut in with the cap off. As the car got warmer the coolant level started raising and dropping getting increasing in level difference as the car got hotter. I allowed this to carry on to the point that the coolant raised so high that it started overflowing from the tank. One more point to add is that the thinner pipe which connects to the top of the header tank got quite a bit hotter than the thicker pipes on the radiator/engine.
What could be causing this? Is there a problem with the new head, water pump, rad???
Thanks very much in advance for any helpful comments
