FIAT Auto Specialist Team
Old 09-04-2013   #1
CV Joint Sei. How to "Pop the circlip".
Hi all,
I'm in the middle of replacing my CV boots on my 200 899 Sei. In Levermircento's guide it says to "Pop the circlip" and the joint will slide off. I can find the circlip but please can someone guide me as to how I pop it off?
I'm at this point:
I assume it's held captive within the joint? What tool do I need? There aren't the holes I would expect to see on a circlip so I don't think it can be by using circlip pliers.
Thanks in anticipation,
Ian.
GrumpyOldMan is offline Reply With Quote Quote
Old 09-04-2013   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: CV Joint Sei. How to "Pop the circlip".
Tap the joint off with a copper hammer is how I always do them. Never done a Sei one though, but it looks the same as most other joints.
Thanks GrumpyOldMan thanked for this post
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 09-04-2013   #3
I'm sorted now. Managed to wedge a screwdriver blade in and the joint did indeed slide off. Very fiddly though and probably isn't the recommended way!
This has to be the dirtiest, oiliest job I have yet undertaken on this car! Stinky stuff too.
Calling it a day now as it's freezing outside,
Ian.
Old 09-04-2013   #4
I done this on my 899 Sei and from what i remember i got two small flat tip screwdrivers and basically spread them and off it came. Bit awkward.
Micsei is offline Reply With Quote Quote
Old 09-04-2013   #5
Quote Originally Posted by Micsei View Post
Sounds very much like how I (eventually) did it. You're right, a bit awkward. Thanks.
Old 09-04-2013   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Bit late to the party, but you can use circlip pliers too.
D
Old 09-04-2013   #7
Quote Originally Posted by rallycinq View Post
D
I didn't have mine to hand at the time but it didn't look like that would work anyway. I'm getting them back tomorrow as I need them to undo the spider thingy.
Very messy job but easier and a lot quicker than I had expected. So far anyway. Bet I regret saying that tomorrow!
Ian.
Old 19-04-2013   #8
Sweden
As it turns out I am in need of doing this too very very soon. Have done that at least three times, best results with circ pliers, but this is still not a fool-proof method, a lot depends on lucky insertion/grip. I need something better, any ideas? I was thinking flat screwdriver with notches cut out on both sides to keep it from sliding out... Oh, and this will be done in situ, I am not touching the hub nut with a ten feet pole. (Come to think of it, that's exactly what I would need )
woj is offline Reply With Quote Quote
Old 20-04-2013   #9
I undid the hub nut with a 3 foot pole! I sprayed it up several times over a couple of days beforehand with plus gas type stuff. When undoing the staking I ended up tearing the outer from one side of the nut. Taking it off was a breeze, didn't even need the brakes applying.
I wanted the hub off as I thought that whilst the shaft was out I would do both boots. It was actually the gearbox end that was leaking oil (899) but no way was I going to take the shaft out again in 6 months to do the CV end, especially as the boots are only about six quid. It also meant I didn't have to fanny about with plastic cones and stuff to install the boots.
Be warned though that the hub nuts no longer seem to be a stock item at Fiat dealers, but they could order me one in. I got one from EuroCarCare as it saved me a trip back to the dealers. I had initially bought a hub nut off ebay but it was waaaaay too short so didn't use it. To their credit though they refunded me straight away. The proper ones also seem to have a built in washer. Cost over £8 inc vat and postage but a necessary thing unfortunately.
Getting the circlip off was just a PITA rather than difficult. I think it's one of those that once you've done it you know how to do it next time. I did it with a flat bladed screwdriver and just twisted until it opened enough to pull the joint out.
Like I said though, this is a REALLY dirty job! Have plenty of rags to hand and plenty of Swarfega.
Ian.
Old 20-04-2013   #10
Sweden
Hub nuts I have a whole box of, I get one with every boot replacement kit I buy (these indeed are not proper Fiat nuts, but those ones I also have floating around). But I never undo the nut, hence a whole collection.
Anyhow, job done, went surprisingly easy this time, circlip pliers, one good grip and the thing was out. Most time was spent getting the grease in and tightening the bands on the boot.
The saddest thing is: they go every two years each side, and the sides are one year aparat in changing, so that means I have to do one every year. Surprisngly, the gearbox side boots are still fine, never touched them for the last 7 years / 120kkm.
While at it I also discovered that my pads are soon to be extinct, oh well, will have another excuse to fiddle with tools
Used to own CCS 1.2T, now it's gone
(T) Stilo 1.2 CV Joint Circlip niksephton Stilo 8 17-04-2012 14:19
(T) CV Joint to Driveshaft Circlip Removal Pull9Gs X1/9 5 19-01-2011 18:06
(G) Tyre just went "pop" - apparently Doug123 Panda 23 01-04-2007 21:14
