Technical Power steering wiring
ghilotina
I got all the parts needed to convert my Cinq to power steering, does anyone has the wiring diagram for the power steering ECU? I have checked all the other threads with no luck.
Thank you in advance.
Thank you for your help, I will look for the sei diagram.
It is not a problem to generate an impulse like the one from the speed sensor. My big problem is how to make the connections between the ecu and the PAS motor and I hope someone who already made this upgrade has the wiring diagram.
As mentioned, they are in the manual on here.
D
This might be helpful too
