So I fitted some new coaxial speakers in the front, mounted on the standard sei grills.
The connection was different though, so I had to cut the original connector off and twist together the wires and tape them. I wasn't fully sure which wires to connect too though, I looked at the standard connector and saw which side they were connected to and just hooked them up that way, they work which is a good sign, but I heard if these are the wrong way around they will work but be distorted and won't sound as good?
On the passenger side speaker the wires were white and red. I connected the white to the negative and red to the positive.
On the drivers side speaker, the wires were pink and black. I connected the black to negative and pink to positive.
Does anybody know which of the colours are positive/negative? or are the wires that are there installed by a previous owner and are just random wires they found?
Any help would be appreciated, as I just hope they're the right way around and not limiting/harming my new speakers.
Thanks.
Edit;
Whilst I'm here, my stereo head-unit is Pioneer DEH-X3500UI (Continous output of 22Watts). & the speakers are 4" PIONEER TS-E1002i's (Nominal input power of 25Watts).
Were those speakers a good match for my headunit? I saw other speakers with higher Nominal/RMS/Continuous wattage, but I read that getting them as close as possible allows the speakers to work at their best?
Thanks.
Edit;
