Hey Everyone,
Last week my Cinquecento Sporting decided to breakdown virtually on the tram tracks near Crystal Peaks, it was a dramatic loss of power that you get when you've ran out of fuel, funnily I had just been to the petrol station to put in fuel.
I then turned off the engine and turned it over again the car kicked up, struggled and cut out, I did it again but this time thrashed the accelerator this seemed to work. I managed to get to Halfway Tram Stop (a mile or so down the road) and it happened again.
At this point I pulled in and opened the bonnet to check for a smell of fuel or any leaks which there was none.
I then decided to risk driving the car round a busy roundabout to get to morrisons petrol station to put in more fuel, to my relief the car made it there. I put in more fuel and the car struggled to kick up though it did and I managed to get home without any problems.
The next day I decided to investigate the fuel issue by inspecting the tank which looked fine, then the filler pipe which looked ok but was covered in a small amount of fuel. I then checked the fuel pump under the inspection panel to see if it was priming when I turned on the ignition which it was, I then realised that the fuel gauge wasn't showing any reading, which was strange as it was working when I turned off the engine the day before. This can't have been the cause of the breakdown could it?
From reading some of the threads on the forum a blocked breather pipe may have caused the issue although I think that air got into the system from the fuel filler cap as this was (apart from adding more fuel) the only thing that changed from the car cutting out and running fairly normally.
Anyway as the fuel gauge now doesn't work i thought I would inspect the fuel sender, as I undid the connectors on the top of the tank there was a build up of this bluey green residue on the terminals. Is this normal? I then proceeded to remove the pump and sender from the tank to remove and inspect the sender further should I have done this as the sender will not budge from the housing at all.
Any advice is welcome regarding the issues raised in this post, sorry for the bible I just thought it would help to establish what happened so you can understand more.
Dancento
P.S. This was my first post on the forum yay!
Dancento
